Whats a decent 45 worth
ChevyKeith
Golden CO
I have always been looking for a decent 45 to add to my collection.
I have often seen them at pretty high prices and wondering from some of you
way more educated on them than me what type of price should I be thinking for a running, not all rusty, decent shape 45.
Thinking mostly stock not heavily modified.
Does LHD vs RHD change price?
Does Gas vs Diesel Change it?
Good question. We're talking pickups, not LVs, right? Like 40s, pigs and 60s it probably comes down to condition, stockness (stock, unmolested should typically be worth more than one with a lot of mods). I'd like to think my stock, unmolested 1978 FJ45 with clean USA title and EPA emission exemption when it was imported from Canada is worth around $20k. It's got a little over 200k kms on it, most everything works and it has a little bit of rust here and there, but no cancer, and paint is pretty faded. With all rust repaired and a fresh paint job it might be worth maybe twice that?
Here's a picture of it from 2009 before the paint got too faded. I used this picture for my Trail Leader column in Toyota Trails when I was TLCA President.
@Rzeppa - I bet your 45 pickup is worth more like $30-35K. It's pretty nice and a little bit of paint fade just adds to the authenticity.
Nice truck. Yes I was talking pickups.
Something like the one you found would be wonderful. Congratulations.
Hahaha, when I first got it in 2004, the seller and I stopped off at Slee's. He came out with a scowl on his face, pointed at my truck and said "I hate those things!". He explained that he'd never go back to leaf springs, too uncomfortable. I guess he spent a fair amount of time in them when he lived in his native South Africa. I'd also expect that because the distance between the steering wheel and the driver is somewhat limited in terms of seat adjustment, it didn't suit his figure. :bolt:
Land Use Coordinator
Keith, have you driven one? I always really really wanted one. Then I tried to drive one... I don't fit! Very cramped at least for someone my size! Disappointing, I love those trucks so much...
ChevyKeith
Golden CO
Good thought. No I have never driven one. As you know, I am a plus sized guy. So maybe this is just a pipe dream. I need to drive one I think to see. Thanks for the warning.
unimogguy
Wheat Ridge, CO
Well…It depends…
As you already know the 45’s are more rare and have more utility value than their smaller FJ40 counterpart.
US Spec 1963-1967 are arguably the most desirable and seem to retain the highest value due to their rarity. Which is why you see so many SA, AUS, etc trucks that have been brought into the US market. Demand outpacing supply. You should definitely know these trucks were used and worked hard especially in foreign countries. There are well known repair issues with SA 40’s the 45’s are no different.
RHD is generally less expensive in the US than LHD. I have both and it only takes a couple hours to get used to the backward shift pattern and sight picture. The sight picture from the right seat is interesting as you’re looking at the edge of the road here in the US. Plus it’s a unique and unusual truck. That said if I sold one the RHD would be first to go.
Gas trucks are generally more desirable as the older diesels are harder to get parts for, perceived to be dirtier/smellier, more expensive to run (gas vs diesel pump prices) and unless you make some modifications aren’t as powerful (HP) as the 2F.
There’s a ton of info on MUD about 45’s they even have their own separate forum and classifieds section the very bottom of the forums page.
Depending on your budget there’s generally several US Spec trucks for sale. Here’s 2 to give you a ballpark. I’m not sure about the age and body sizes of the guys who commented above but I’m 6’2” and 220. I fit in all 3 of mine. Now I will tell you that the SWB is not a good option for those of us who have larger frame or belly sizes and I definitely wouldn’t want to take it on any long distance trips. If I had any of my 45’s out here I’d happily let you come over and sit in any or all of them.
$17k
CA red truck unfortunately it’s had a V-8 conversion done, radio was cut into the dash and it got repainted. But…It has all the really hard to find parts and is rust free from an extremely well known CruiserHead.
I just happen to know a guy who recently purchased a huge ‘67 FJ-45 parts lot (engine, trans, transfer and a ton of misc parts) from a $300k+ retro mod build and would be willing to part with whatever is needed to see this truck back on the road in stock configuration.
$35k shipping to a CA US port included
‘62/‘63 SWB (You’d be hard pressed today to replicate it especially with the current prices for a project SWB and the rare **read expensive** parts)
Also you could always consider buying an AQUALU frame, 6” or 12” extended cab to be able to push the seat back further and their bed. After having seen my buddy Arya’s FJ-40 buggy with an Aqualu body be pushed up against some rocks and the almost 0 damage (other than scratches) that resulted I can attest to the quality and thickness of the body’s construction and strength.
I’ve got a tan LPB (full length) Aqualu 45 bed I’d part with if you decide to go this way.
I am much happier with my "later" 45 than a '63-67 since it has all the improvements of a 1978 '40, such as 2F, H42, dash pad, recirculating ball bearing steering box, vacuum brake booster, etc. It also has a FF rear and is a bonafide one ton truck, with 9 leaves in each rear spring pack and 3" wide drums. It even has the factory Denso AM radio.
Boulder Cruiser
Boulder Co
I’m biased but I prefer the early 45 to the later. The early 45 feels like a true utilitarian machine, it’s a completely different experience than driving a later model. It’s hard to describe the feeling but I prefer driving my 45 over any of my other cruisers.
The SWB removable top will give you about the same interior room as a later model 45. The cabin is larger than its fixed top counterpart.
You’re welcome to come take mine for a spin!
