What are the odds
nsfw
that the magic smoke comes out of my CB if I don’t tune the antenna?
I have an old Cobra CB that was in the bed of a truck I bought years ago and I picked up a Cobra mag mount antenna. Everything seems to be working but I don’t have an antenna tuner or anyone close with a CB to even let me know if it’s transmitting.
Appreciate any guidance from the radio fellas.
nsfw
Just what I wanted to hear. Only using it for Cruise Moab so acceptable is great.
There's a limit to how bad you can get away with. Stage 1 is a little bit off, you leave a little bit of performance on the table. Stage 2 is pretty far off but still in the ball park, the radio will reduce power to protect itself. Stage 3 is really bad, shorted or no antenna at all, that can ruin it.
The good thing is if the antenna and mount were bought from a store and not modified the risk for stage 3 is low as long as there's no obvious issues. Main thing would be that the coax cable and connector don't have any obvious corrosion, cuts, flat spot or kinks.
BTW, antenna-wise the risk for harm only occurs when you transmit. So if you're not sure start with short transmissions. If it seems you're not hearing other stations well that's an indication of a poor antenna but there's no harm to the radio in having a mismatched antenna when receiving.
twentyfooteighty
Salida, CO
Where are you located? I have an SWB meter and can tune it well enough for you. Also, I can tune it for you at CM on Wednesday if that helps as well.
nsfw
I’m out in Byers. Gonna try to get to the meeting tomorrow, so maybe you or someone can tune it there. Thanks for offering.
twentyfooteighty
Salida, CO
nice. I will make sure that I have it with me just in case. I am the tall goofy dude that talks too much.
twentyfooteighty
Salida, CO
I just put my hands on it. I'll bring it with me just in case you show.
twentyfooteighty
Salida, CO
Also, it just occurred to me that we are using FRS at CM this year. We can still tune your antenna anyhow, so that you have another option for comms.
J1000
Morrison, CO
I was also looking forward to tuning my CB at CM so I'll hang out with you guys.
twentyfooteighty
Salida, CO
I can tune yours tomorrow if you plan to be at the shop.
nsfw
Awesome. Thanks. I’ll be there tonight. I’m doing the Kokopelli run, so CB is still required.
Kokopelli uses only tin cans and string. o_O It's an upgrade from smoke signals and whistles.
