BC9392
- Joined
- Feb 6, 2019
- Messages
- 138
Thoughts on 99 Toyota 4Runner with Sonora Steel Classic 1.2 lift kit.
http://www.sonoransteel.com/index.php?main_page=index&cPath=1_9
I have a 1999 Toyota 4Runner with a 4.30 locking rear and so here’s the information I can provide you about this lift
Kit uses - Front: 2004 Tundra TRD front coils with Bilstein 5100 shocks, re-valved and re-fitted for 4Runner. Rear: 95 Toyota FCJ – 80 Land Cruiser coils and Tokico black heavy duty shocks
Stock front bumper so 2 1/2 inches on the lift on the front. 3 1/2 lift rear
Before and after dimensions.
Center of rear wheel to bottom of fender. Before 21 inches. After 25 inches
Center of front wheel to bottom of fender. Before 21 1/2 inches after 24 inches
Ground to bottom of rocker panel at center. Before 18 inches after 21 1/2 inches
Ground to bottom of rear sway bar mount. Before 12 1/4 inches after 16 inches.
Crossbars to ground. Before 12 inches after 16 inches
I elected when I did this lift to replace upper and lower ball joints. I also replaced one wheel bearing on the front due to looseness. Thought was it’s cheaper to replace them while doing the kit then it is to have a failure on the trail. I did this myself and it’s very easy getting loaner tools from Advance & O’Reilys. Be glad to discuss if questions. Or go see Youtube- Timmy the Toolman. https://www.youtube.com/channel/UC9EMiD9KPy61kJ6hdXcbjxA
Overall impression.
Instructions are well written had no problem doing installation. If you do I would suggest replacing the rear brake line 1st before doing any of the rear lift kit. After the kit is installed it really stresses the line should you forget and release your floor jack.
Because you’re doing a differential drop the center mount bolts on the skid plate do not go all the way up to the frame. Sonoran doesn’t feel this is a problem but I put spaces in so I could bolt it tight. You do need to follow their instructions and use the short bolts they provide where the front and rear plate bolt together.
When installing the rear springs I used a spring compressor because it made it just a little bit easier to get the springs in.
Ride quality is good although I feel the rear is a quite firmer than stock. I have been out twice and have gotten compliments on the great articulation that it has.
I’m now running 265/75 x R16 BFG KO2 tires but would like to find a set of 285/75R16 to see how they perform.
Any questions about kit or if interested in seeing /riding, please let me know.
My concern now is identifying any weak link areas - front drive shafts ?? - and determining how to prevent failure. I don't like trail repair.
Any thoughts - send them my way.
Bob Crossman BC9392@gmail.com 804-347-3568
Overall impression.
