Everybody and his brother has a heep...be original. Count 'em...around here *almost* one vehicle in 20 is some sort of heep, not all CJs, YJs or TJs, but even those are pretty common. 40s look better anyway.
Take my friend, and I'll make this quick: Sept. 02 bought '81 CJ7 for $4200. Needed steering box but that was about it. Couple weeks later his engine developed a knock, and while they were inspecting it they found 3 of 9 front pinion teeth missing. Transmission didn't shift good. So they decided they had to rebuild the engine, main bearings were gone, so they ended up replacing the tranny and rebuilding the x-fer at the same time. Got it running by Nov. or so, he took it driving in 2wd around town then his rear end blew up on him! So he spent the rest of the winter swapping out front and rear axles to Dana 44. By Spring 03 he was driving again, but didn't like the carb so in summer 03 he got fuel injection. Then in fall 04 the body started showing MAJOR rust bubbles that had been covered up with a paint job. So he's talking about replacing the body/tub and he still doesn't like the power of the 258 so he's talking about swapping engines again. He's also still on 31 x 10.50's with 3.56 gearing and now he's got somewhere around $15 grand total in it.
My truck: bought in Jan 05 for $3500, drove back from GJ the day we bought it. Needed small stuff, fuel tank vent leak, exhaust leak, heater broke, no w/s washer assy, some other odds and ends, but ran pretty good etc. I've spent the last couple years working on mostly the little things, but the tranny, t-case, diffs and front axle either showed no signs of heavy wear/breakage, or just needed to be cleaned up and new seals, parts etc. I've spent a total of around $7 grand not including tires on my truck, and I have a heavier duty drivetrain and more body clearance than my buddy plus a rear locker.
Obviously the story could have been reversed, and his truck is still cleaner than mine, but I still think that I've gotten away for a pretty good deal considering mine's 30 years old and seems to have been somewhat neglected/unmaintained. Obviously a newer TJ is going to require less maintenance etc., and older 40s and heeps are going to necessarily require more maintenance time, or in my case, more time to bring the truck up to an acceptable level for normal regular operation, but that comes with a territory. But there's lots of guys here and on MUD that have found cleaner trucks than mine for about the same money; my dad and I were kinda looking for a running project truck that I could dink around with but that started out running and I could go bash in the woods. That's prolly more than
![TwoCents :twocents: :twocents:](http://www.risingsun4x4club.org/forum2/images/smilies/2c.gif)
, but that's still my
