Solid Axle T100
TrailRigRacing
The new springs fit real nice. When turned fully to the right there were some clearance issues between the tie rod and the radius arm. Trimmed up the radius arm to clear the tie rod.
How's the driveshaft angle w/ the offset 80 rear and centered output of the Tcase?
TrailRigRacing
I got the dual transfer cases in the truck. The front control arm crossmember is going to require some modification to clear the driveshaft. I will need to modify and reuse the factory t-case crossmember to mount them.
