VoodooBlue_Vixen
I recently pulled the synthetic line off of the old warn winch that came on my 1st Gen 4Runner, when I held a winch maintenance day for a few LOT gals. I knew it was going to be bad news bears before I started, but the farther I got into that line, the WORSE it was. I wouldn't use that line for a dog leash, let alone a recovery tool... The last wrap was rusted to the reel, and I had to peel the line off through the rust.
I'm going to be working on repairing the reel, not sure how badly damaged it is quite yet. But when I do get to a point of being able to rewrap some line on it, I want to buy the real deal, not some cheap knock off.
I've found a company called TRE (https://www.tacticalrecoveryequipment.com) where one can order UHMWPE Synthetic Rope coated with a UV protectant at any length in just about any diameter needed with/without heavy duty thimbles added as requested.
Does anyone have any experience with them? Are they a good supplier to buy from, or should they be added to the stay away from list? Do you have a trusted supplier you've ordered your winch line from in the past?
