Pre, pre, run.....bang!
treerootCO
only one problem with the axle swap. My beer froze :hill:
treerootCO
I had to winch off that hill:p: I knew I would get high centered but I did it anyway. The swap was only a one :beer: so you can't blame that. I also got to use one of my new jackstands I got for Christmas.
The stub would not come out so I welded a slide hammer deal to it. Popped right out.
treerootCO
Need to change out the straight 60 weight tomorrow. It turns over real hard in the cold for some reason. :D
Need to replace the tierod, find the tools, and remove the smog pump. It is starting to lock up and the tierod is still bent from the Chinaman's run.
