Nissan Frontier EV Conversion
J1000
Morrison, CO
Battery boxes fitted to the truck and they barely fit! Literally less than 1/2" of clearance, but clearance is clearance!
Next up, filling the boxes with the battery cells and completing the HV wiring.
J1000
Morrison, CO
In the final stages of this build now. The main high voltage battery is installed and sealed up. All the major systems are buttoned up and back together.
Just need to get the interior put back together and figure out the bed lift system. The bench seat is getting reupholstered and having heating elements installed in it. Once it's back in the truck we can test drive it!
Wired the LED driving lights to come on with the high beams:
Look into low riders and how they did bed lifts back in the day...
I'm hoping to use a 12v linear actuator vs. installing an air system, but right now anything is on the table. Would be cool to have hydraulics and have a real dump bed but it's not in the cards.
no air or hydro. i was thinking more along the lines of something like a piano hinge and some gas struts and just manual power...
Just my thought.... build looks great
J1000
Morrison, CO
Good idea, I thought about gas struts as well. That's probably the simplest and best.
Awesome!
I didn’t see this until after I asked on IG.
KISS is one of the best methods some times.
J1000
Morrison, CO
She's alive! Wow it drives amazing!!! 4th gear is functional. 3rd gear is fun. 2nd gear is a riot. 1st gear is tractionless.
I only drove it for a few laps around the private warehouse area. Done maybe 40 or 45 MPH maximum. Speedometer isn't working. We missed our DMV appointment this week but are scheduled next week.
Awesome! Job well done Jimmy! I want to see EV burn out videos!!
60wag
Wow, that looks great! - way better than that stainless steel door stop you are parked next to. I just noticed the crazy windshield wiper on the Tesla. WTF?
Wow that's amazing Jimmy... yeah we need to see the burn out for sure, dang.
Will the brake pump always be that loud?
Does it have a manual gear box in it still??
J1000
Morrison, CO
The brake pump is louder in the video than in real life but it's still annoying. I worked yesterday to dampen it a bit, it was just bolted to the firewall. Also the relay as well clicks loudly. I've been working on it and got some parts coming to solve it because it's so annoying and really takes away from the rest of the vehicle.
And yes it still has the 5-speed transmission.
rushthezeppelin
How does a manual work with an electric motor since it doesn't stall? Do you literally just use the clutch for gear changes only?
MarkEva
What is the radiator cooling?
What a great thing to do with young people.
that is so cool. So in reverse, you still get all the gears?
