Need ideas to fix this...
rushthezeppelin
So I have this bent cam tab ear. I can't get straight on it with a punch because of the rack mount to the left that sticks out. I tried getting under it with a prybar and it just wants to bend the whole tab since it's only welded to the frame at the top. Same thing when I try to get it with a big pair of channel locks, whole thing tries to bend. Any ideas? My plan is to try and bend it back enough to hold the cam so I can at least drive it long enough till I can get this kit Marlin Crawler just released welded on. https://www.marlincrawler.com/armor/axles/hd-lca-frame-mount-upgrade-kit-1996-2002-4runner
I have the Marlin kit on my truck. It's an option once you get everything back straight as reinforcement. Having been displaced and beat/prying straight those ears are going to be soft and likely to just tear off at the next alignment.
In your case I think you may consider the Total Chaos solution. This replaces the whole bracket with heavy duty ears.
A concern I'd have is the way yours are put together. There should be 3 spot welds holding the plate on from the factory and not a single weld at the top. If I was guessing someone before you broke it and the fix was less than ideal.
RDub
Boulder, CO
Maybe put a bolt in it with a large washer to keep it flat, then try to bend the tab with pliers or similar?
rushthezeppelin
That's an idea!!
rushthezeppelin
Yup it worked!
rushthezeppelin
rushthezeppelin
I think your right. That one actually had two welds after looking closer but yeah it looks like a few of them have been replaced. Pretty sure I'm not the first one to wheel this truck and that's where the tabs usually get bent.
i'm going this route eventfully on our 3rd gen
There's a gotcha with these kits. You lose the infinite cam and only get 3 positions for the lower arm. For a truck that's primarily for trails this is sufficient and no worse (maybe better) than a driveway alignment.
But for a truck that does a lot of highway you need adjustable upper ball joints and an alignment tech with some experience to maybe dial it in. With regular fixed UCA it's going to be tough to get neutral handling and minimize tire wear. Those cams are doing both camber and caster on our trucks.
Now based on my alignment record having just min/mid/max for the lower arms is probably not going to make alignment outcomes any more of a crap-shoot. So there's that.
rushthezeppelin
This, I think the octagonal cam eliminators are a better choice if you want to avoid losing alignment but have better adjustability. TBH though as long as your alignment tech gets the proper torque there should be enough clamping force to not lose alignment, I never lost alignment from offroading on my rig. It also doesn't eliminate the possibility of taking a hit like Adam or I did and flattening a cam tab. Only tab gussets or a fat weld bead will do that.
True, those alignment tabs should not be holding anything and the clamping force should be sufficient under normal use. I think loosening the bolts too much, tweaked frames and rust result in having much more difficulty getting them to turn and a mechanic reaching for a longer bar is certainly the most likely reason they bend.
But we push trucks considerably harder than the factory assumed when we rock crawl, put on lifts, change bump stop (and travel) and larger tires. So having thick or reinforced tabs isn't wholly without merit. It's my experience that alignment does seem to drift over time even without obvious damage. But it's only really when you've put in a double case or lower gears, run >33", etc and routinely hammer it. I've had trips coming home that the truck got a new pull to the shoulder even with a IFS brace and Budbuilt skid.
IOW when you've pushed the IFS geometry to the design margin. You can only torque the bolts so much before they stretch (are these marked non-reusable in the FSM by chance, I don't remember) so there's a limit on clamping force. Toyota balanced this against the forces they expected to hold against. Eventually something can slip.
rushthezeppelin
I don't think my fsm marks them as not reusable. I think the issue is that most alignment techs aren't going to get them to the 96ftlbs torque spec because the rack is legit in the way of getting an actual torque wrench in there. The probably just hand ugga dugga it as much as they can with a crescent or a box wrench. I ended up checking checking torque on all 4 while I had the rack out of the way and the front two were fine but the back driver was actually a little under spec. That said it did survive a hard hit on Yankee 2 1/2 weeks ago on the ice shelf that took out Andy's ring and pinion Saturday. I think the only way to truly torque them properly is with (at least in the case of 3rd gen 4runners) use a 22mm crowsfoot and do the calculations for the increased length.
rushthezeppelin
Well thankfully that seems to be the only damage. Got it all put back together and I went from major toe in to slight toe out and camber looks eyeball good. Ever so slight pull to the right and steering wheel is now about 35 degrees off. Should be all good once I can get it back to Tru for another alignment though.
