Machining Services Needed-1FZ-FE cylinder head
masperk
Hello!
I can’t find anyone to replace my head gasket, so I am jumping in.
I am planning on pulling the head on my 80 series this weekend.
I need to replace the head gasket on my 80 series and was trying to line up a machine shop.
I am looking to do a leak test, valve job, deck the head and replace the valve guides.
**any other machining services recommended for this head while it is out?**
(I have replaced all hoses, corrected wiring harness near fuel rail, phh, all new egr valve, emissions equipment/sensors/tubing under hood, thermostat, OEM pump water/steering all hoses etc. then cylinder head popped)-confirmed via hydrocarbon test and notorious cyl 5/6 misfire.
Can someone recommend a shop? Located in Denver. Thank you! Any help or advice appreciated!
I used these guys when my 4Runner needed head work.
Colorado Custom Cylinder Heads
3260 S Platte River Dr E, Englewood, CO 80110
(303) 761-9077
Gunn Automotive in Denver is pretty awesome for cruiser stuff, I've taken them several heads including the 1FZ head I did for the 80 last summer. One before that was a 2F head. You can have them set all the valve clearances also if you want it easy and just get it back and slap it on.
-Marco
