masperk
- Joined
- Jan 21, 2020
- Messages
- 34
Hello!
I can’t find anyone to replace my head gasket, so I am jumping in.
I am planning on pulling the head on my 80 series this weekend.
I need to replace the head gasket on my 80 series and was trying to line up a machine shop.
I am looking to do a leak test, valve job, deck the head and replace the valve guides.
**any other machining services recommended for this head while it is out?**
(I have replaced all hoses, corrected wiring harness near fuel rail, phh, all new egr valve, emissions equipment/sensors/tubing under hood, thermostat, OEM pump water/steering all hoses etc. then cylinder head popped)-confirmed via hydrocarbon test and notorious cyl 5/6 misfire.
Can someone recommend a shop? Located in Denver. Thank you! Any help or advice appreciated!
