You may have noticed I am selling my 40. The last few years I have only driven it about once a month. (Photo by TreerootCO)
I also have a BMW Z4. Pretty fun to drive especially with the top down. As long as there issn’t snow on the ground, this is the vehicle I typically use for short errands as long as I don’t need to haul anything. Not much room for picking up stuff
My wife won’t ride in either of these so the 200 gets the work when we go places together or I need to haul something or bad weather. She doesn’t like the Z4 because it is too small and low to the ground.
Neither of these vehicles give me a lot of Utility
The 200 series is a keeper. Does everything I want and after 8 years of ownership has 97K miles on the clock
Over the years I have thought it would be great if I had a truck for getting stuff from the hardware store, hauling stuff to family, etc. It would provide utility I don’t have. My wife would also ride in it or even drive it if need be. I know, get the Tundra. The Tundra’s length would fit in my garage, but it would force me to modify some of my work bench area. Plus it is wide. I feel it is too big for what I want, but not ruled completely out.
I have been reading reviews and watching videos on the Tacoma 4th gen out now and am intrigued. The 4th gen update is really nice with the rear coils, 14” entertainment system yada yada
I like the changes to the 4th gen including rear coils instead of leaf springs and the updated interior and entertainment system. However, no experience in a Tacoma so can only go off the reviews posted on-line comparing 2023 vs 2024
View: https://www.youtube.com/watch?v=BnapCwZ2YfE
I would sell the 40 and likely trade the BMW Z4 in unless I buy an older Truck
The two models I am looking at are the Tacoma TRD Offroad with I4 (not Imax hybrid) and the TRD Pro which only comes with the 1-Max Hybrid
So Romer, what does this have to do with Towing? I am glad you asked
I am keeping the 200 as my main wheeling and camping vehicle. But you never know the future, so if I buy a truck it has to be capable of off roading where I like to go and tow my Kimberley Karavan.
The 2023 Tacoma TRD Off Road and TRD Pro both have a capability of 6500 pounds towing with the I6
The 2024 TRD Off road (non hybrid) has a capability of 6500 pounds
The 2024 TRD Pro with the iMAX Hybrid has a capability of 6000 pounds as does the TRD Offroad with the i-Max. The Hybrid system due to its weight reduces the towing capability by 500 pounds. This is also the capability for the new Toyota Land Cruiser 250 (I-Max engine)
Interesting enough my 100 series had a capability of 6500 pounds so assuming the performance is similar. Slow slow and steady up a Mtn pass
I read someplace a safe factor for your actual towing weight to capability is 75%. Have no idea if true or valid
So that would mean I6, and I-4 non Hybrid Tacoma’s shouldn’t tow anything greater than 4875 pounds to be safe
I-4 I-Max Hybrid Tacoma’s (and LC 250) shouldn’t tow anything greater than 4500 pounds to be safe.
Come on Romer get to the point
I want to make sure whatever I get can safely tow my Kimberley Karavan over the Mtn passes. It isn’t a primary vehicle so Towing capability performance (i.e speed up the pass) isn’t a driver, only that it can safely tow if I decide to take a Tacoma to Moab one year
The specs on my Kimberley Karavan
Dry weight – 3550 pounds based on actual measurements from owners in Australia
Gross Weight fully loaded -4850 pounds fully loaded based on actual measurements. However 418 pounds is two full water tanks and 70 pounds are two jerry cans. I could fill the water tanks in Moab or after the passes. I Know someone who does this with a larger and heavy trailer being pulled by a 200. So I could reduce the weight 250 (Half tanks)- 500 (empty) pounds depending on how full and how much extra gas I carry and fill up in the flatlands. Kimberley specs the GVWR at 5500 pounds, I am using actual measurements from several Australian owners fully loaded.
My view is I should base it off being fully loaded;
Really looking at the Tacoma right now 😊
No I am not asking you which Tacoma to get. My question is relative to towing and what is safe based on specified Trailering capability for the vehicle. Maybe because Toyota is conservative, anything up to the spec limit is safe?? This is where I could use some help. I intentionally did not include the hitch weight in this discussion. I don’t see that as an issue.
Sorry for the long winded post. Thought it would help to understand why I am thinking about it
Thoughts? Any real world data or better information out there on this topic?
Lets discuss looking at Vehicle Trailering Capability towards what is actually safe to tow over our Mountain Passes
- Any 2023 Tacoma model can safely tow it
- The 2024 Tacoma TRD Off Road non Hybrid version could safely haul it
- If I reduce the water I carry, then even the I-Max Hybrid vehicles could carry it
