J Kimmel
Thought I would put some photos up of my new build...in the midst of changing everything around a 4th time on my Toyota pickup, a friend came across this chassis and it was too good to pass up. I started putting pen to paper to figure out what exactly I needed to complete on my old one and I figured this would be almost as much work, but I am starting with a clean template. I don't have to re-engineer what Toyota intended for what I want out of it. Ultimately I am after a small, nimble, light weight crawler built with the right parts.
this is roughly what it will look like competed...he is saying his is 2900 lbs with Suzuki/toyota drivetrain. I'm hoping for 3500 lbs with my drivetrain. I'm keeping my one ton axles, and my 22re. I am swapping in an AW4 with an A340 bell housing so I can run a 5.0 Atlas behind it.
I opted to get mine un-welded so I could weld it, and I wanted to make a few changes, mostly to the b-pillar supports.
