Groucho
Nakman is correct. I have drawn up and prototyped replicas of the bulldog mounts using the old Con-Ferr mount as a sample. I tried to attach a .pdf so that you can look at the design, but my file was too big. If you want me to email it to you, send me a pm.
The brackets are powdercoated a durable gray color, called "Mock-Rock". But I could powdercoat any color the group wants. If you want them Clear Zinc Plated like the sample Con-Ferr was, that can be done but will cost $3 more.
Cost with powdercoating?
$25 per bracket, minimum order 60 brackets.
Cost with clear zinc plating?
$28 per bracket, minimum order 60 brackets.
60 brackets means that 10 people would have to commit to buying 6 brackets(3 per side of the truck) each.
Any interest?
Any interest?
