I'd pull some connectors, maybe start with the one on the throttle position sensor. Connectors and wires are another place where it's pretty easy to force water in.I let the truck idle in my driveway after work and the CEL came back. I’m getting codes 26 and 41 (air fuel ratio rich and throttle body position sensor). They’ve come and gone since car wash yesterday and the truck runs differently when they’re on, which seems to be at idle. Any ideas?
Drove a bit more this afternoon. Truck ran like crap when first idling then completely normal when driving, even at red lights.
Yup, I mean just pull the connector off the TPS (for example) and make sure there's no water trapped. The gotcha here is if you do force water past a seal like this it can't get back out under normal pressure. So it's just stuck there.Like the wiring pigtail connections I’m assuming?
