I would do what Andy suggested and tighten the wheel bearing. Sometimes the loosen up a bit. Its maybe 30 minutes and free to at least see if that is the issue. You can still do the rebuild again.
Agreed with Ken and Andy, grumbling in the front is usually wheel bearings, but that doesn't account for 2WD no noise/4WD The noise! The observation that you got some looseness with the 12 o'clock/6 o'clock test goes back to maybe knuckle bearings but still rules out on the 2WD/4WD test. Definitely a head scratcher! You can't know until you verify that the wheel bearings are properly pre-loaded I guess.
