DR-X rust remover
RS Club TLCA Delegate
Looks like it works great. Thanks for the tip!
I've been planning on trying Evapo Rust on some projects but I haven't pulled the trigger yet. I've watched too much youtube and now/then guys bust out magic elixirs like Evapo Rust.
Do you have a feel for how the two rust removers compare? All good one way or another, just wondering.
Allen
Thanks Kurt, definitely gonna try that stuff! FYI it is back in stock and on sale, $19.99 a quart.
Allen, I saw the "What? No way!" guy tried Evaporust and it looked pretty amazing. I tried it on a bunch of pliers, hand saw, garden shears etc that I had left outside in the rain and were rusted shut. Soaked overnight and they looked brand new! Shot them with some lube/rust preventer and it's like I bought new tools. :)
So I figured I'd give it a whirl. The instructions say you're supposed to rinse it off after its dwell time (5-10 minutes), so i made one spray bottle with water and one with Dr. X. They also suggested that you can dry it off with a hair dryer (they said not to use compressed air because it might contain oil).
So for my first test, I chose a fairly heavily rust chunk of diamond plate that's been sitting around in my garage for many years. The first squirts didn't make any visible difference. The instructions say that after the 5-10 minute dwell, try again if needed. I squirted the top middle section of this plate 3 times, and waited 10 minutes after each try, then I rinsed water and dried with the hair dryer. I could sorta kinda see a little difference, but nothing like what I was expecting from what i read upthread here. Well, maybe it was too heavily rusted?
So I thought I'd try something easier with only a light coating of rust. I chose the bearing cap of one of the bearings of the swing-out on my 60. The first picture is before I started. Then each subsequent picture is after an application of Dr. X and waiting 10 minutes. Bear in mind that most all chemical reactions are affected by temperature. This was all done in my heated, room-temperature garage. Speaking of chemical reactions, I got the distinct odor of sulfur dioxide as the stuff was reacting, so we can probably assume sulfuric acid is in the formulation. Honestly, the appearance (kind of a brown, translucent coffee color) reminded me of the stuff we used to passivate stainless steel with, which contained both sulfuric and phosphoric acid, along with inhibitors.
So while it isn't total snake-oil, it certainly isn't some magic-miracle process either! IOW, don't toss your wirewheels, 3M abrasive wheels, sandblaster and sanders out quite yet!
J1000
Morrison, CO
I used it on some parts that were heavily rusted and then hit them with a power washer and I was surprised how well it did. Not perfect but a lot of the rust came off and exposed bare metal.
Also, be mindful of where you use it. It will eat through concrete so it probably is acid
white wings
I had some heavier frame rust on one of my cruisers that required a flap disc first and then this treatment (followed by the rinse product) then the wipe down air dry, and then the Eastwood encapsulator frame paint.
Took the afternoon last sunday but I was very happy with the results.
066wally
Allen
Evapo Rust is excellent if you can soak the parts, usually about 24 hrs. I don't think it would work as a spray-on, I've never tried. It is also non-toxic and reusable. Rinse parts with water after treatment.
