Brucker
This is already very picture heavy so I will limit the amount I post about the painting process. But everything that needed to, got primed. Then everything that needed to get painted white, got painted white. Then everything that needed to get painted black, got painted black.
Once everything was coated and it had cured, the final assembly process began. This is when all the correct hardware is used, any lock tight or lubrication is applied as needed, and everything is properly tightened and torqued.
