WildCrustacean
- Joined
- Jun 24, 2023
- Messages
- 51
New thread from a discussion in the snow run thread about recovery anchor points (@rushthezeppelin).
This is the front right side of my truck, there is a broken bolt stuck in one of the threaded holes in the frame that I would like to eventually use to mount an anchor point:
I don't know if it initially broke off or if it was cut off, but it's cut/broken flush with the frame. There is some surface rust on the frame but overall it isn't that bad. I'm guessing that this bolt is rusted in though somehow.
I soaked it in PB blaster for a couple days, then drilled out the middle and tried to use a bolt extractor, which then snapped off and neatly filled the hole I drilled... so I gave up since I can at least put an anchor on the other side on the front for now.
I'm not sure what to do next, other than re-drill it out and try again. The only other thing I know to do is get a nut welded to the bolt fragment to try to get it out, but I'd need someone with a welding machine to do that.
