brake question
Hey all you 40 guys...'77 FJ40 - when I press the brake pedal I get a whooshing sound like air being pressed out of a diaphram. After the pedal goes down a little ways then the brakes engage and the old girl stops. If I repeatedly press the brakes then there is less whooshing and more brake engagement. Is this a sign of master cylinder blowby? After the brakes engage, the pedal elevation holds steady, it doesn't drop to the floor.
Northside
Good and bad news.....
Good news...it's not your master cyl! :thumb:
Bad news....your brake vacuum booster is toast :(
upgrade to an fj60 booster. max is parting one out...see howmuch he wants. it's bolt up, albeit upside down, but that doesn't affect performance and you've a much better chance of finding a good fj60 booster than a good 40 booster
treerootCO
Don't run too long that way. Even though you may have brakes, the leaking booster makes the #6 run really really lean. Worst case...you will burn a hole through the piston :(
Okay, thanks for the quick responses ever'body. So will a minitruck booster work okay as well? I have a BUNCH of credit at the Yota Yard from my stupid minitruck MAF/ECU screwup last year and have nothing to spend it on.
Hijack: Maybe somebody who needs minitruck parts could hook up with me this summer and help me use that credit...
treerootCO
pick up all the parts needed for a disc brake swap and sell it as a package deal on the eBay....
