Bolt size Q
IanB
0
Just this side of reality.
Are the small bolts that stop spring pins from spinning on a 40 a standard JIS bolt? Part #23 below. I have the old ones but want new ones and want to know if I can get them at Fastenal.
Shark Bait
Parker, CO
New ones? Chrome plated? I usually just clean mine up.
Going for the Bling factor, Ian? :)
BTW, I gave the 55 column to Kevin last night.
Good luck!
Stock spring center pin bolts are M8x1.25 with 12mm head. That's JIS. Aftermarket are whatever.
Edit: Should have paid closer attention to the original post: The spring end pin bolts are also M8 x 1.25 with 12mm head JIS. IIRC stock is about 25mm long. In that applicatiob DIN/ISO will also work, as there is plenty of clearance for the 13mm heads. Also in that application, in my experience, those bolts don't matter to get you home :-)
IanB
0
Not exactly, but I have the the sandblasted/painted springs and the brand new OME greasable shackles and greasable pins on the sandblasted and painted frame and new ubolts and center pins and... it just seems a damn shame to put rusty old bolts back in with all that. :eek:
Thanks for the column man. That is one of the last major parts I need for reassembly. Also, Kevin and I were looking at the splines on the end of the shaft I have out of the guts of a 60 column and it looks like the same spline as the 55 column you gave me, I think I may just need to cobble together a couple of OEM driveshaft u-joints to mate the 55 column to the 60 ps box.
Shark Bait
Parker, CO
I should have offered. I've got 55 column ends. I always end up destroying the u-joints when I pull them apart, though. Let me know if you're missing something.
