Best tire groover?
@Uncle Ben had a really good writeup with pictures when he grooved his swampers some years ago. I don't know if he monitors our forum much any more, maybe contact him direct? This was WAY before MUD, maybe it was in Toyota Trails? LCML days for sure.
DomOfTheDead
Event Coordinator
lakewood
I use a 120v model I have had for years and love it. Just recently, I cut my Cooper STT pro's and it brought new life to them
ScaldedDog
Sedalia, CO/NSB, FL
I've used one like this (https://www.amazon.com/Ideal-902-00...mzn1.fos.304cacc1-b508-45fb-a37f-a2c47c48c32f) on two sets of Pitbulls, and it's worked well.
Mark
BritKLR
ATC HQ - Nederland, Colo.
That right there is a good idea for a event demo or workshop. Would love to see this work in person.
DomOfTheDead
Event Coordinator
lakewood
Cool idea. I will look into setting this up
RS Moderator
ScaldedDog
Sedalia, CO/NSB, FL
were you able to make full depth cuts in one pass? And how long per tire if you recall.
I could across each lug, though my cuts weren't quite full depth. Probably something like 1/4 - 5/16" deep. I'm thinking each tire took 30-45 minutes, but that's a little fuzzy.
Heat is your friend when using one of these. Start with a fresh blade, let it get hot, and work on the tires indoors and in as warm a state as you can reasonably get them.
Mark
ScaldedDog
Sedalia, CO/NSB, FL
my detached garage without heat then should be perfect this month. :banghead:
LOL! You could do it, but I think it would take longer and require a little more muscle. Try one, though, as I could be wrong. I've always done them in the spring, on a warmish day.
Mark
DomOfTheDead
Event Coordinator
lakewood
ScaldedDog
Sedalia, CO/NSB, FL
@Corbet, you inspired me to work on my Pitbulls some more, since tons and stickies are losing out to all the other things that need money around here. I deepened the existing grooves, and grooved every lug I had just siped before.
I'm not a weight weenie, at all, when it comes to tires, but this effort did put them on a diet:
I was doing it in my 50* shop. I could have gotten it warmer, but was having to work hard enough that I didn't want the heater on. You'll figure this out, but a respirator is your friend, as is ventilation. No pun intended, but you're literally burning rubber, and only a few inches from your face.
Mark
