Looking for a little help this morning... Drove to the hardware store and the truck started and ran as normal. Gauges looked fine. I came out from the store and tried to start my truck and was greeted by a metal-on-metal rotational sound. It is not a “grinding” sound, not a ticking, and not a “teeth chewing themselves apart” sound either. You know in old Kung-fu movies when the samurai draws his blade out of its sheath? It sounds like that - a scraping noise, and definitely rotational. Starter? Banging on it doesn’t change anything. As an amateur mechanic I’m at a loss here. What do you say, great people of the Rising Sun forum? I wish I could upload a video for you, but that doesn’t seem to be possible.
checked the following:
-All fluids good in engine bay are good
-Motor turns by hand
-Starting in neutral so it’s in the engine bay, not transmission or transfer case (I think)
-Placed phone in engine bay and took a few videos while starting, everything turns as it should
-Everything attached to the engine is tight - dizzy, starter, oil filter and cooler brackets, all accessory brackets (PS pump, alt, smog pump)
-Radiator fan turns freely
-Engine bay video show smog pump pulley turning
-No new leaks
-No new leaks
