I’ve got one, and I have tried to track it down a couple of times with no avail. Anyone have some time this coming weekend to help a brother out?
What all have you tried? How much draw? Unfortunately I don’t have time, but I’ve tracked down quite a few over various platforms over the years.I’ve got one, and I have tried to track it down a couple of times with no avail. Anyone have some time this coming weekend to help a brother out?
I hear ya. If I trickle charge the battery back to 12.7v, it is usually down to 11.9 within a few days. Then I repeat the process. I had a battery that cratered about a year ago, replaced it 6 months later with a warranty swap (Costco Interstate), then late last week replaced with an X2 Power AGM.In judging how bad a parasitic is you first need to make sure you have a problem at all.
The normal threshold for "excessive" in anything with an ECU or electronics is 50mA constant draw. But a mid 1990s Toyota should be around half of that, say 25mA or so, before you can really say you're tracking down more than normal.
A 92 A-hr battery in absolutely new condition and starting fully charged with a 25mA load will in theory reach 0% in 3680 hours, about 150 days. But for most batteries that are in the middle of their life and not starting from 100% (Toyotas chronically under charge) it'll be much less. Plus, that's only supplying the constant load. Being able to start after a period of sitting is not nearly as long. You need something in the tank to crank the starter, so even ideal battery at 25mA you can only take so much.
So for most of us just driving and parking our truck that isn't an FJ40 or 20R mini a month is about all you can count on under perfect conditions, a week or two in the middle of winter could be a marginal battery.
Another question is whether this happens in the summer, too, or just winter? A battery at 32°F can only source 60% of the current that it can at 75°F. Then when it gets really cold, at 0°F a battery can only get you 20% of its rating.
Now taking that a step further, what criteria are you using to say you have a parasitic? Not being able to start or just battery voltage? Are you sure your battery isn't just tired?
To give context to Damon's concern this is a generalized State of Charge (SoC) chart that relates voltage to condition. It's more accurate to measure current going in and out of a battery to know but voltage is close enough and of course much easier.I hear ya. If I trickle charge the battery back to 12.7v, it is usually down to 11.9 within a few days. Then I repeat the process. I had a battery that cratered about a year ago, replaced it 6 months later with a warranty swap (Costco Interstate), then late last week replaced with an X2 Power AGM.
I had a parasitic draw in my 80 for a while that I fixed. It was the factory amplifier that was used with the original head unit. I had replaced the head unit within a day of buying my 80 back in 2004, but the old factory amp was still there behind the dashboard, drawing power. It's behind the dash on the passenger (right) side. You can simply unplug it to see if it fixes the problem. I eventually completely removed it.
so you replaced your AGM with something else?Since I’ve replaced my AGM dura (not gunna) last battery and the original alternator (260,000 miles), it appears to be holding voltage after a few days. I’m still charting the voltage.
