DouglasVB
So this happened this weekend... I was having too much fun working on the truck to actually go 4x4ing. Whoops!
Not pictured are two lights that shine out to the right and left. These are specifically for setting up camp at night.
I'm finishing up wiring details for switches in the cab and I am planning to uprate the relay for the light bar (currently rated for 30A continuous but not accounting for engine bay heat). Also I need to switch out the main fuse for the fuse panel I'm running the lights on for a circuit breaker with a higher rated current. I'll be drawing about 42 amps total (about 500 watts of LEDs) if all of the lights are on. Currently I have a 30 amp fuse for the whole fuse panel. I'm not terribly comfortable with putting in a 50 amp fuse. I'd rather have a 50 amp circuit breaker. The reason being that I don't terribly trust the fuse holder that is rated at 60 amps but being from a local auto parts store... I'm not confident in the wire gauge.
Tomorrow I need to pick up some small gauge wire (~18-20 gauge) to run into the cab for the switches I will be installing. I should be all set for the spooky night run for Halloween!
In the future I'll put rock lights in the wheel wells. That will happen after the SASing this winter.
so it gets first priority over everything else.
