CBone
I discovered a small oil leak in my truck. It seems to be coming out from the timing cover. There is a small skid plate located near the steering stabilizer and when I removed that I discovered where the leak was coming from. I've attached two pictures looking up from under the truck. The leak is pretty small and it seems it may be the timing cover gasket. Based on my limited knowledge, seems like a pretty tough fix. Can someone who has experienced this provide a little guidance? Thanks in advance.
