3 speed vs 4 speed pics?
RS Club TLCA Delegate
OK, been searching on Mud and Google and SOR and various places, and do not have a definitive picture of the differences between 3 speed and 4 speed trannies and tcases. Any hints? Could be helpful as I search for the elusive 4 speed tcase...
Thanks.
T
Does the 3spd tcase have an aluminum housing like the 4spd?
treerootCO
Thanks.
T
A three speed transmission is the size of a cantaloupe. A four speed transmission is the size of a watermelon.
T-cases are all spec-ed out here:
http://www.ih8mud.com/tech/cases.php
and
http://www.kinzers.com/don/landcruiser/tcase_tech/
and
http://cjford.stormloader.com/Tech/transfer1.htm
and...
yes
input cutout on the bellhousing on a three speed is round, 4 speed is peanut shaped
does that mean the tranny itself has a difference?
ok, thanks for the links Root, but I am more confused now. :rolleyes: (big surprise) As I understand it, I would need a "4 speed" tcase to work with my 4 speed tranny...the pics from the links show 3 "3 speed" tcases and 3 "4 speed tcases" and show the differences between a brittle case and a softer case, and between a 3 speed case and a non-USA case, but the 70 - 1/75 (3 speed) case looks exactly like the '74 - 7/78 and the 7/78 - 7/80 4 speed tcases. What obvious thing am I overlooking here? :) Thanks.
T
in da house
in da house
Yes on the 4 speed input shaft end it's more of an 8.
Shark Bait
Parker, CO
Timm, You're still welcome to my 4-speed t-case shell. It was set up with 3-speed gears when I took them out to put them in my Orion. So the idler gear should be "set". And my offer is still good for helping you put some 3-speed gears into the 4-speed case if you get the rebuild kit and the conversion gear kit. The only other thing you will need besides a gasket to go between the tranny and the transfer case is the bolts for the 4-speed t-case to bolt to the 4-speed tranny. I don't have any extra of those. :D
Shark Bait
Parker, CO
Bring it over here. I even have a parts washer. :D
Below, a 3 speed housing is on the left, 4 speed on the right.
As I discovered when I did my 4 speed tranny to 3 speed t-case conversion, you will also need a spacer for the tranny output shaft so the washer and bolt will fit, and you *may* need a spacer for the PTO gear if the t-case originally had a PTO gear.
I had a number of "gotchas" that came up during the install which I had never read about or heard about before.
