2010 Wheel Bearing Packing Party (WBPP)
Perhaps an 80 expert can chime in on the rotors. We do remove the rotors but I'm not clear in my recollection on what they are attached to and what is involved is swapping. If you do this, you should have the new rotors on hand and ready to go. There is not enough time in the schedule to take them out and get them turned.
No worries. As I wrote - swap. Not turn. I know they are attached to the hub and that the hub is slid off the spindle to repack the birf. Just checked Mud "All you have to do is remove the bolts that connect the hub to the rotor and install the hub on a new rotor" http://forum.ih8mud.com/80-series-tech/292265-replacing-front-rotors-brake-pads.html (which BTW is an overall good front hub service write-up).
I will be a little late but should be there by around 10:00 or 10:30.
Ricardo, keep my number handy in case you need me to pick anything up on my way in.
Justin
SRT08BUS
Colorado
I'm out, I've been called into work.
Old40Dog
Thanks for all of your work on this Ricardo!:bowdown: See you Saturday, if I don't see you Friday at the CBC. Stiil not sure about CBC, but I'll let you know.
TIMZTOY
ill be there.. i can also mentor, ill bring a few tools. i have a nice digital torque wrench and air tools i can bring.. i also need to change my oil and check all my other oil's, and greese all my zerks (im lazy) :rolleyes:
and the 80 rotors are just bolted to the back of the hub, which is taken off to do the bearings.. so easy to swap to new ones
SRT08BUS
Colorado
I might still show up so I can pay for my name tag and TLCA badge, I don't think I'm gonna be able to make it to the meeting.
Land Use Coordinator
I am bringing the parts washer...just need something to put in it...left the old fluid at the exes house and can't run over there tonight. maybe just 5 gallons of diesel??
Rock Dog
in a house
Hello Daniel, i rebuilt my 80 front end last year... I found my left front spindle eaten up pretty good once i got it all opened up.... hopefully yours are in better shape. I will bring my spare.. I will try to be there and also bring my fish scale (i used to set the bearings).... i also have a big hub socket (i believe 2 1/8'') that is beefy, and i have used for years...
I beleive this place is right next to Aligment Masters..... I have been going to alignment masters for years, and have nothing but good things to say about them..... and Mi Concina on the corner has great Chilie rellenos!
Neil.
Nemo
Guys,
I am still going to show but later. I am backing out of doing the Front Bearing Repack this weekend but I should learn a ton from you guys. So one off the bearing pack for the 80 but am willing to help once I arrive. :p:
