Other side is similar:
There is a guy on mud that makes brass bushings fyi.
Looking good Marco, yeah once you dial in the hinges on the door frames and cowl the rest comes together easily. Looking good, you'll want bronze bushings too not brass. Brass is too sticky, bronze is the slick stuff. Kurt sells a set of nylon ones that were really good but the on/off/on/off of the seasons killed mine pretty quick. Once you go bronze you'll be all set. I am going to try a set of the bushings on my hood hinges as my old ones are toast causing a rattle and fitment issues.
I use drilled out 38 special brass and it works perfectly!
