Troopy build out
what a sick build!! i love it!
Capriblue45
The GP factor fold down table came back in stock so I pulled the trigger for it. This table is specifically built for the 70 series by a US company. The 1/4" rear panel replaces the fiberboard trim on the right rear door and fits very nice. It clears my build out by 1/2" with the door closed and is very well made. This was the final piece to make the cooking area efficient.
Those are great! I had something similar on my 77. It was great for lunch, place to set stuff, etc.
Capriblue45
I picked up a short bus bumper from Marco some time ago and I am finally getting around to modifying it to fit on the troopy. I cut out the damaged 80 mounting brackets and will be making custom brackets to adapt it to the 70 frame. I also shortened the wings by 3" per side to make it look better with the narrower front of a troopy. I will be infilling the top to match the green tape to follow the angle of the troopies fenders. Going to take some work but I think it will look good once done. I guess we are never truly done building these rigs.
Capriblue45
Here are few pictures of the completed slee short bus on the troopy. I have a winch coming for it in the next few days. I was a bit worried about the added weight on the front but my 200 #'s did not even move the front leaf springs so I guess a 65# winch is not going to be an issue.
Capriblue45
They are the factory springs, I believe these things came with one tons.
Capriblue45
Here's the last of the mods ( I think). Mounted a privacy cube on the passenger side for changing, showering, toilet etc. deploys and folds up very quickly and best of all takes up no space in the truck. Wife approved.
You'll like that when group camping.
Looking fantastic Mike! better put a lock on that thing or you'll have visitors in the AM :ROFLMAO:, is there a curtain for the window to the inside??:bolt:
Capriblue45
It has the same material against the cab with a zipper that you can open if you have a slider or gullwing to access the inside of the truck. Also comes with a dimmable LED light strip on the inside for the middle of the night toilet runs.
