2011 Specialized Stumpjumper (Comp?) medium $450 ($420 BBB):
https://denver.craigslist.org/bik/d/2011-specialized-stumperjumper/6532117435.html
DRIVETRAIN
CHAIN KMC X10, 10-speed, w/ reuseable Missing Link, nickel plates
BOTTOM BRACKET SRAM GXP, outboard bearing
CRANKSET Custom SRAM S-1250, GXP spindle, 10-speed, 7050 alloy arms, S: 170mm, others: 175mm
FRONT DERAILLEUR SRAM X.7, 10-speed, S1 direct mount for DMD, bottom pull
SHIFT LEVERS SRAM X.7, 10-speed, aluminum trigger
CASSETTE Shimano HG81, 10-speed, 11-36t
CHAINRINGS 22A/33A/44A, 4-bolt, 104/64mm
REAR DERAILLEUR SRAM X.9, 10-speed, long cage
SUSPENSION
FORK RockShox Revelation RL, Dual Air, 140mm travel, disc only, alloy steerer, Motion Control damper, rebound and compression adj. w/LO
REAR SHOCK Custom Fox Triad II for Specialized, custom on-the-fly 3-position switch 1) lock out 2) Open 3) ProPedal pedal assisting damping, rebound adj., 7.875x1.9"
WHEELS
FRONT HUB Specialized Hi Lo disc, laser-etched logo, OS 28 end caps, sealed cartridge bearing, 28h, 9mm thru-axle QR
REAR HUB Specialized Hi Lo disc, double sealed cartridge bearing, OS contact side, 32h, QR
INNER TUBES Ultralight presta valve
SPOKES DT Swiss Champion 1.8mm (15g) stainless
FRONT TIRE S-Works Purgatory, 120 TPI, 2Bliss ready aramid bead, dual compound, 26x2.2""
RIMS Custom DT Swiss X420SL, 24mm w/ eyelets, 28h
REAR TIRE Specialized ""The Captain"" Control, 60 TPI, 2Bliss ready aramid bead, dual compound, 26x2.0"
COCKPIT
SADDLE Specialized BG Henge Comp, hollow Cr-Mo rails, 143mm width
SEATPOST 2014 butted alloy, single bolt setback, 30.9mm, S/M: 350mm, others: 400mm
STEM Specialized XC, 3D forged alloy, 4-bolt, 31.8mm clamp, adjustable rise
HANDLEBARS Specialized XC low-rise bar, 2014 butted alloy, 680mm wide, 8 degree back sweep, 6 degree up, 31.8mm
GRIPS Specialized lock-on, S/M: Grappler, Other: Rocca
BRAKES
FRONT BRAKE Custom Avid Elixir R SL, hydraulic disc, alloy backed semi-metallic pads, reach adjust, stainless hardware, S/M: 185mm, L/XL: 203mm rotor
BRAKE LEVERS Custom Avid Elixir R SL hydraulic, tool-less reach adj.
REAR BRAKE Custom Avid Elixir R SL, hydralic disk, alloy backed semi-metallic pads, reach adjust, stainless hardware, S/M: 160mm, L/XL: 185mm
ACCESSORIES
PEDALS Resin Test Ride Pedals with toe clips, CEN std.
FRAMESET
HEADSET 1 1/8"" upper and lower campy style cartridge bearings for integrated alloy HT
SEAT BINDER 34.9mm clamp ID, 7050 hard annodized alloy collar w/ QR, black
FRAME M5 manipulated alloy w/ ORE TT/DT, sealed cartridge bearing pivots, replaceable derailleur hanger, 140mm travel
Alternately:
Wheels and Tires
Hubs: Specialized Hi Lo disc
Tires: Specialized tubeless-ready, Front: S-Works Purgatory, 26 x 2.2; Rear: The Captain Control, 26 x 2.0
Spoke Brand: DT Swiss 1.8mm, stainless-steel
Components
Brakeset: Avid Elixir R SL disc, 7/6-inch rotors
Shift Levers: SRAM X7
Rear Cogs: Shimano, 10-speed: 11-36
Saddle: Specialized BG Henge Comp
Handlebar: Specialized XC low-rise
Handlebar Stem: Specialized XC adjustable rise
Factory Description
Through tree-lined trails and across the high plains, over roots, rocks and sweet singletrack, Specialized's Stumpjumper FSR Comp rides smooth and confident. Its light M5-aluminum frame is mated to the legendary FSR suspension system for super efficient climbing, while the 140mm of buttery travel front and rear lets you attack the descents with unmatched voracity. Fox supplies the shock, RockShox, the fork - and they're both tunable to the trail and how you want to ride it. To keep you railing, the Comp features lightweight DT Swiss wheels, a flawless SRAM 3x10 drivetrain and powerful Avid Elixir discs that stop strong in even the nastiest conditions. Plus, you get a whole spread of Specialized's stellar components, too.
