I also have a 5 ton pintle hook that'll bolt there, if you are looking for something as recovery. Down side of a pintle is it's a serious knee buster, though it looks core. I may still have a bracket like Martin mentions, too, not sure.
These are really easy to build, I made one of these for my rear bumper. You can pick up the receiver piece from Walmart, Autozone, etc for $10 and get the HD chunk of angle iron from Fastenal if you want new for another $10. I could weld this for you in about 2 minutes. Pick up some grade 8 bolts and drill 4 - 1/2" holes and you're done.
Yes, its for recovery. I removed the bumper "log" that was on there, which also included a rear recovery point, and I have no plans to put it back on the rig. And I've got one of those receiver-mount D-ring dealios sitting in my garage, so I thought I'd put it to use on the 40.
Building might be an option way out in the future, but I've got too many other things on the list right now, and not enough time....
So I kinda dropped this for a while, but still need one. The square tube style is preferred because I have one of those Warn slide-in recovery dealios that holds a D-ring.
