Spiderlegs
- Joined
- Nov 14, 2005
- Messages
- 71
I need help with the best speaker set up in an fj40? All pics and ideas are welcome.
Thanks!
Thanks!
I've used some square boxes made of MDF, covered in fabric and tucked in the back corner between the roll cage and the tub, speakers firing up.
I like what you did with the hardtop and my question is when you make the kicks will you still be able to use the kick vents. If yes let me know I may have you make up a set for me too.Hey! I used to do that in college, too! I totally agree with everything you mentioned...and I'll add...
When you are looking to get an amp and speakers, try to match the amp power fairly closely to the speakers' power handling rating. That is...if you go get a 50x4 amp and hook up speakers rated to 1000w each - that amp can't really push enough juice to make those speakers 'sing'. I chose to match things like this...I have a 50x4 (RMS) that peaks at 90. My speakers are rated to like 120. That will help maximize the potential sound quality.
RMS = Root Mean Squared (I believe?) but refers to the 'constant' wattage being pushed, typically they peak higher.
As you get deeper into this stuff and want to get a "clean" amp - look for the lowest THD%. I think that means Total Harmonic Distortion - you want low. Like I had an old Alphasonic amp back in the late eighties that was like .002% THD. Although it was only like 35w RMS man...it sounded GREAT.
Now...it's been alot of years, and alot more so I hope I remembered that stuff correctly...
HTH
