It's gonna be almost impossible to install a new crush sleeve while the diff is in the truck... if it is anything like a minitruck diff. But if you did.. you did. Goodonya. The only difficulty I see is the near impossibility of determining pinion preload torque without a
1) dial inch/lb torque wrench, and
2) removing the diff from the housing, and
3) removing the carrier from the diff.
My opinion only, I defer to 'Da Boyz':
However you may be able to redneck it if you carefully crush the sleeve until you only just eliminate any play you feel, then crush just a bit more. You won't (shouldn't!) have enough backlash to really measure the pinion preload, but you may be able to tell by feel. Maybe.
I would not run the resulting assembly across country though. Pinion bearings like some preload but get fussy about too much or too little and will leave you 'in a tight spot' and shed bits all over, which makes a lot of noise and screws everything else up. I rather suspect they are female in nature. They definitely spin around fast, that must be it.
Carrier bearings must be male. Crank the hell out of the preload, give em appropriate quantities of fine fluid, and run them forever until everything around them falls apart. Then they die. Yep... Male.
Bill,
I chatted with Marco a bit about this.
Agreed that a set up needs to be done on the bench, but this diff is done anyway. From the amount of backlash he was talking about, its not good.
He's getting them rebuilt in Memphis with his new gears, and, I believe, a new carrier.
I told him exactly what you said, IE tigten it down until there is not play, then just a hair more. Not too far. It sounded like he got it.
Figured it would last for the next 1000 miles or so, enough to get to memphis. Or at least across the snow belt and he can swap the front in if needed.
I guess he'll see. We may see a post up on mud asking for help with a beige FJ-60 with a blown rear end needing a tow somewhere in the middle of kansas...
As I told marco though, I'm certainly no expert. I've read a lot, done a couple, and paid Robbie to build one and explain everything to me as he did it. Still feel like I just BARELY know whats going on in there.
Figured, if he didn't punch it, and baby'd it as much as possible, he'd get there.
