A couple things I need:
For the u-shaped radiator support, there are two carriage-bolt style bolts that bolt that support to the frame. One of mine is bent and is no longer avail. from Toyota. Rather than buying some generic carriage bolt from somewhere I'd like to install with OEM components. Does anybody have one sitting around? If not I might have to put it together with some non-OEM/JIS style hardware and figure it out later.
For the bib hinge that mounts to the frame, does anybody have the bolts/washers/nuts that came from the factory sitting around? The non-JIS hardware that is currently serving this duty really irritated me (because I had forgotten it was non-JIS) this time and I'd rather not put it back on.
OR - does anybody know any parts yards in Denver that currently have FJ40s in their inventory? I have tomorrow (Friday) off and may be able to squeeze some time to go to one or two and pull some stuff. If I don't make it tomorrow then the next time someone goes to a parts yard could you pull these for me? Thanks
