I've had an ongoing problem with voltage drop in my '85 FJ60. Voltage is fine while running and idling, except when I turn on the headlights, or use the blinkers at idle, I drop below 12V. I have a newish alternator and regulator, upgraded IPF headlights and relayed ARB headlight harness connected to the battery and I have tried the fused direct connection from alternator to battery. Any ideas what to look for? Or is the alternator just not up to the task?
This causes an issue with my National Luna dual battery setup. When the voltage drops, it turns off the solenoid to the second battery, so it's not getting a charge and gets really low after a few days. Ive disconnected the second battery from the system for the time being.
Any tips appreciated.
