CBone
Steve,
Sent you a PM about setting up a time, as I do not have a vacuum gauge.
Martin, those are great ideas, thanks. The window in the carb has fuel right to where it should, but i will check for an obstruction before the filter.
Also, without a vacuum gauge Kvanoort and I were limited, but we did run the tests we could on the EGR Modulator and found it did not work due to a clogged filter. I removed the filter and it worked fine, as it should as detailed in the FSM. The EGR itself needs to be tested with the vacuum gauge and a foot on the gas pedal, for the reasons Steve described.
Thanks everyone for your continued suggestions. This is what you get when you go to add bling to a 25 year old truck
nah, the lines I replaced were old and cracked, so this needed to happen anyway.
