ferretlegger
Hello,
I live in Moab and have a built Tacoma. in the last two years I have had a serious problem with the rear drum brakes after doing some hard winching. It appears that the brake shoes can essentially weld themselves to the drum if there is enough pressure applied to them. When one releases the brakes and goes to drive off, the truck will not move until a bit of throttle is applied. Then there is a huge BANG! as the brake shoes (glued to the drum) destroy the pivot point at the bottom of the brake shoe assembly and are ripped out of alignment inside the brake drum. This causes the brake cylinder pistons to be pushed out of the brake cylinder. As a result, all the brake fluid gets dumped onto the ground and the brakes ( both front and back) do not work.
I have had this happen twice, and in addition to being awkward and expensive to fix, it leaves me kind of uncertain about using them this way again. As a result, last winter I put a Dana 60 rear end in, with FJ Cruiser disc brakes on each side instead of drum brakes. There is still a small drum for a parking brake (as with FJ Cruisers and 4Runners), but it is pretty small and not at all going to hold against a hard winch pull. The main advantage is that there is no way that a blown parking brake can take out the disc brakes.
So the question now is how can I keep the truck from moving during a hard winching operation? I do carry and use two BEEFY wheel chocks, but I would like something in the brake system to keep the truck motionless while on a steep incline so I can get out of the vehicle and place the chocks. One solution is to stand on the brakes, which works great as long as the engine is on. But when I turn the engine off the only thing keeping it motionless is the (tiny) parking brake, which is not very effective on a really steep hill. Certainly I cannot winch against it.
Some discussion with local offroad gurus in Moab have pointed me at Line Locks as a possible solution. A Line Lock is a solenoid valve in series with the brake line coming from the master cylinder to the disc brakes. When de-energized, the brake fluid passes unrestricted to and from the brake. If the brakes are pressed firmly and the solenoid valve is actuated, either electrically or manually, the brakes in the circuit are isolated with the applied pressure continuing to hold them pressing on the rotor. Line locks are frequently used to lock the front wheels during burnouts. I have been assured that most of Rory Iverson's rigs in Moab use manually operated line locks as high strength "parking brakes" during rescue operations.
So my question to you is: What do you think of adding line locks to the front (or rear or both) brakes for use in critical holding situations? Apparently having a Line Lock in series with a brake is legal as long as there is a separate mechanical parking brake and the line lock is not used as a parking brake on streets. In my case, since I have ABS and ATRAC, to lock all 4 wheels I would have to install a line lock in each of the 4 brake lines (or pair of lines), and energize them (if using electric solenoids). That seems both expensive and hard to do, although it could allow for front digs.
Questions: Does anyone have any sources of electronically controlled Line Locks to suggest. It would be great to find one with 2 separate channels controlled by one electrical line to actuate either the front or rear two brakes simultaneously.
Also does anyone have any experience doing this? Pitfalls? Downside? My hope is that this will foster some discussion about how people control their rigs when winching, as I cannot be the first person to have this problem.
Thanks for any insight you might have, and I look forward to seeing you in Moab!
Cheers,
Michael
Cheers,
Michael
