Everything is CNC'd. From the back to front, there is a perfboard that has an outline that matches everything else and the holes to align the spacers that start the board stack
Next up is what I call the motor mount plate, it just supports the motors and the steel stop pins for the needle home position and the LCD display.
The EL layer (TBD) will be a insulated thin layer with the individually CNC cut meter backlights and interconnected with copper self adhesive tape.
The artwork layer is a laser printed vellum that is applied to a thin clear plastic, once mounted I register it in the mill and cut the inside and outside profiles using the four needle centers as my datum points. (Incidentally, I was delighted to see my big HP color laserjet will hold to +/- .001 or so, far better than the artwork I was getting from the office supply place).
Then there is the mask layer that has that pebbled look in between the meters.
Then the top layer is a 1/2" thick slab of 6061 with the pocketing and chamfering.
I only plan on replacing the perfboard with a PCB now, but may do the EL layer that way as well and route it myself on the mill with my high speed spindle.
The only assembly I don't build is the Arduino microcontroller, they are dirt cheap.
