Tacoma recall
I was up at Pedersen yesterday afternoon, picking my truck up after doing this TSB rear spring recall inspection. I'll be getting new rear springs eventually but Toyota is backordered by a month on spring packs due to the volume apparently. There were two Tacomas in front of me for leaf spring inspections and a couple after.
And it was interesting, they were getting two new 2nd gen frames for the supposed frame rot that doesn't exist.
'98 is a third gen right? Did those have issues?
1st gen Tacoma (1995 to 2004). They were under a recall for frame replacements. These have a very serious potential for rot. Part of the reason was no one knew to look for it and some got so bad as to actually break in half. At the time (and the recall is still open AFAIK) affected 1995 to 2000 trucks were bought back by Toyota and destroyed while 2001-2004 were eligible for new frames. This was a 15 year warranty, so a 1998 would no longer be covered after 2013.
The 3rd gen is 1989-1995 Pickups. These were domestic derivatives of the Hilux. After roughly 1992 they were made in the Fremont plant, same as made the Tacoma. They don't have quite the serious rot issue that Tacomas seem to, although they are not immune to typical rusting out. The Pickup/Hilux frames are pretty overbuilt and the quality seems to be better.
For some reason the combination of wall thickness, geometry, paint and anti-corrosion coatings are Tacoma make them prone to terrible rot. Currently the 2005 to 2009 2nd gen Tacomas are covered under a frame recall, however the inspect-by date is already passed. The ones that were brought in for inspection are either marked as done (with a corrosion warranty I think) or they are currently getting replaced (such as Taco Dane's). Mine wasn't bad enough to justify replacement so I've been aggressive in treating rust.
AimCOTaco
Longmont, CO
Marco,
The 98 4-runner is a 3rd gen runner but a 98 taco is a first gen taco.
The first gen Taco was assembled in CA with frames from Dana in Mexico. The 3rd gen 4-runner was built in Japan and imported so you don't have nearly the same concerns on a runner as you would on a Tacoma.
ahhhh yes, I forgot to mention the vehicle I am asking in reference to was a 98' 4runner. I assumed they were practically the same underneath! oops!
SteveH
Colo Springs
Not in Colo., but I have seen east-coast '98 4Runners with Swiss-cheese frames for sale in Colorado. I was astounded at how bad the rust was - 12" sections of the bottom of the frame missing, ahead of the rear spring hanger.
The location Steve refers has been an issue on Pickups and 4Runners forever. It's the section of frame that transitions up from the long under-cab length to the rear section over the axle. Since the Hilux frames are fully boxed they tend to pack in with mud and rot. This was part of the problem with 1st gen Tacoma frames, too, since the frame was boxed there still.
The current Taco frame is open-C most of the way to allow muck to clear. So the rot is different. It seems to be most often found under the driver's A-pillar region and may have to do with how close the catalytic converter is to the frame. It cooks the coating off I guess.
You really want to stay on top of it regardless the model or county of origin. Even the Japanese trucks use thinner steel in the frames than they used to.
Caribou Sandstorm
This is really helpful info Dave!
I wondered why C frame vs. Box.. FJs, 4runners, Landcruisers have box frames... But they don't seem to have the same rust issues??
Also, I am kind of leaning away from the TRD Pro this Fall vs. a TRD Sport.
I like the darker gray color and I am going to want a 2-3" lift vs the TRD Pro's 1" lift.
Thinking I can get a better deal on the TRD Sport also and put that money saved into lift/wheels/tires..
