I think I figured out why my t-case was leaking so much - the front output nose cone didn't have a gasket between it and the body of the t-case!
I would like to inspect my gear real quick to make sure they didn't get toasted from running out of oil, but it looks like the t-case is kindof a pain to pull - could I just remove the PTO cover and look inside? Or should I just buckle up and pull the t-case and open up the top inspection cover? Any tricks? From the FSM, it looks like after I take the 5 bolts off if should just slide off, but then reading Jeff's resto page there's a bunch of stuff that has to get installed as you put the t-case back on...hmmm I'll probably just bite the bullet and do it.
