It's getting to be a problem.Looking crowded up there and only about half the intended have been deployed. Satellitemap.space
We aren't that far from just moving their observation equipment into space... Problem solved!It's getting to be a problem.
Starlink satellites are disrupting cosmic studies | Astronomy.com
The fleet of Starlink satellites interferes with astronomical observations, a study published in Astronomy and Astrophysics has revealed.www.astronomy.com
Brought to you by Carl's JrWe aren't that far from just moving their observation equipment into space... Problem solved!
I was curious and I'm sure you're amongst the no doubt vast, vast number of others who might be too.We aren't that far from just moving their observation equipment into space... Problem solved!
This graph is what has sold me that we are starting a real space race. The cost per Kg is set to drop to levels that wouldn't have been believed just 20 years ago. As I understand it, many of these telescopes and observatories would obtain better results as well if they didn't have to pass through the atmosphere.I was curious and I'm sure you're amongst the no doubt vast, vast number of others who might be too.
I count 683 observatories on this list (this includes spacecraft)
List of astronomical observatories - Wikipedia
en.wikipedia.org
So I drilled down. There's been 117 launched, 39 still active.
List of space telescopes - Wikipedia
en.wikipedia.org
16 gamma ray (5 active)
38 x-ray (11 active)
22 UV (7 active)
12 visible (8 active)
13 IR and sub-mm (4 active)
4 microwave (1 active)
2 RF (zero active)
9 particle (3 active)
1 gavity (zero active)
13 to be launched
Doesn't really mean anything, just an observation. Pun intended.
Does seem like a lot of hardware to be obsoleted or at least hobbled. That seems unfortunate.
It's not 100% overlap since some of the space observatories do things that couldn't be done from Earth in any case. There's also been many spacecraft launched that are not in orbit but other than Voyager they're still in our Solar System so the stars are for orienting themselves still.
