• RS MAY CLUB MEETING
For Sale Spring Cleaning Sale!!
PVCsnorkel
Longmont, CO
I finally got time to sort through my buckets of parts and have assembled an inventory of what I do not need. It is all 60 series and 2F parts.
I will attach pictures to the next post in the thread.
QuantityPart Description NotesPrice
1Power Steering Pump Complete$50
1Power Steering Pump Core$30
1PS Pump Reservoir$20
1Brake Booster and Master Cylinder$80
1Rear Hatch Wiper Motor Assembly$80
2Charcoal Canister Bracket$15
1Power Steering Pump Bracket$30
1Alternator Bracket$30
1Set of Hood Spring Hinges$40
1Exhaust Manifold Flap ValveGasket Included, No bolts$15
1Master Cylinder - Brakes$30
1Front Hubcaps$40
1Rear Bumper with CapsDriver Quality; Local Sale Only$30
1Set of 60 Mirrors$50
1Set of Lower Rear Hatch Cover PlatesGray$60
1Spare Tire Carrier CrossmemberLocal Sale Only$50
4Tow HooksChrome, Black, 2x Bare$25
Brown Rear Seatbelt Set$50 for the set
2Rear Seat Belt SpoolsBrown$15
2Rear Seat Belt BuckleBrown$15
1Rear Seat Belt Lap BeltBrown$15
1Front Seatbelt Gray$20
1HVAC Center Display Panel$20
1Door Handle and Rod$10
2Amber Fender Markers$20
1Pass. Front Turn Signal Lense$20
2Dome Light Housing$10
1Dash Cubby$10
1Ashtray Brown$10
1GrillDriver Quality, Few tabs are Broken$100
12F Valve Cover$100
1Big Front Brake Upgrade SetRotors, Hubs, Calipers$100
EGR Part Set$150 for the Set
1EGR Cooler$40
1EGR Pipe$25
1Vacuum Switching Assembly$50
1"Spaghetti Vacuum Lines"$25
1EGR Valve$20
2Exhaust Heat Shields$10
1Long Range Fuel TankNeeds cleaning/refurbishment6 Pack
PVCsnorkel
Longmont, CO
PVCsnorkel
Longmont, CO
PVCsnorkel
Longmont, CO
Telly
Monument
I may be interested in the power steering stuff. I'll get back to you here real quick.
Edit: I'm going to pass on the power steering parts. I'm tempted to hoard but running out of room to stash stuff.
RDub
Boulder, CO
I’m looking for the exhaust heat shield that covers the front exhaust manifold horn, by the PA pump. Do you have one?
PVCsnorkel
Longmont, CO
I believe so. I'll send pictures of the heat shields I have
PVCsnorkel
Longmont, CO
What is the history on the master cylinder?
The master attached to the Booster has sold. The only other one I had I pulled from my 60, it needs to be rebuilt as the seals are worn.
PVCsnorkel
Longmont, CO
satchel
Erie Co
Anyone know if the rear bumper for a 60 would work on a 62? I technically only need the end caps.
RDub
Boulder, CO
@satchel I think the rear bumper is the same on
both models, end caps included. Looked at a couple of online places that sell OEM bumpers and the rear bumper and parts are listed as 60/62.
PVCsnorkel
Longmont, CO
I still have a set of end caps if you need them.
