Welcome To Live Chat
3:14:01 PM System Jeffrey H has joined the chat!
3:15:38 PM Jeffrey H Hello Matt, thank you for contacting Live Support. My name is Jeff. I would be glad to assist you with this today!
3:15:49 PM Matt Farr We're having problems with our vBulletin forum at risingsun4x4club.org/forum2
3:16:12 PM Matt Farr This is a new issue, and we did not change any settings or make any modifications.
3:19:24 PM Jeffrey H Can you provide a bit more information regarding the issue you are experiencing today?
3:21:18 PM Matt Farr Private Messages not sending properly. Also, users getting errror message that reads: "Your submission could not be processed because a security token was missing or mismatched."
3:22:19 PM Jeffrey H I will gladly get to the password first.
3:22:23 PM Jeffrey H Rather, next.
3:22:32 PM Jeffrey H Lets see why these messages are not sending correctly currently.
3:22:40 PM Jeffrey H How are you trying to send messages?
3:23:06 PM Matt Farr risingsun4x4club.org/forum2/private.php
3:23:43 PM Matt Farr To be clear, several users have reported this problem. Three people in 24 hours.
3:23:56 PM Matt Farr However, I haven't seen it myself.
3:24:53 PM Jeffrey H Does your site have a timeout on logins or idle browser sessions?
3:26:07 PM Matt Farr Not that I have ever seen.
3:27:23 PM Jeffrey H Although I am not able to assist with third party software or such customizations or coding, I was able to locate the following forum which may contain additional advise on how you may extend the time limit: vbulletin.com/forum/forum/vbulletin-legacy-versions-products/legacy-vbulletin-versions/vbulletin-3-6-questions-problems-and-troubleshooting/266477-change-session-timeout
3:27:26 PM Jeffrey H Does this help?
3:28:26 PM Matt Farr Can you take a look to see if there is a problem on your end that might be causing this?
3:28:56 PM Matt Farr As I mentioned, we haven't changes ANY configurations on the forum, and it's been running on hostgator for more than 10 years.
3:29:10 PM Matt Farr Could it be a database connection issue?
3:29:23 PM Matt Farr Do you have logs that you can look at for the last couple of days?
3:30:45 PM Jeffrey H In the event of a database connection issue, the site itself would not be able to display properly.
3:30:58 PM Jeffrey H This is an issue with the configuration of vBulletin.
3:31:22 PM Jeffrey H If you require any further assistance, I would advise contacting a third party developer. For now, is there any thing else I can assist you with today?
3:32:26 PM Matt Farr Jeffrey, I am not satisfied that you have investigated this thoroughly.
3:33:14 PM Matt Farr Have there been any changes on the HG side that we should be aware of?
3:33:36 PM Matt Farr Did server software get upgraded or modified in the last week?
3:34:34 PM Matt Farr I waited on hold for 30 minutes to chat with you -- I'd like you to investigate this. I am highly dubious this is an issue with vBulletin.
3:37:58 PM Jeffrey H Do you have a test login I can use to test this?
3:38:25 PM Matt Farr For the server or for vBulletin?
3:38:33 PM Jeffrey H I will gladly provide all the insights necessary for you to make an informed decision as to how you should proceed with this. However, again it appears this is a setting within vBulletin.
3:38:44 PM Jeffrey H For vBulletin. I would have to replicate the error to proceed.
3:39:12 PM Matt Farr What information are you seeing that makes you suspect that vBulletin is the culprit?
3:41:14 PM Jeffrey H There is a login, and when people are idle on web applications for long enough. Their session gets reset, which is likely why your customers are seeing this and you are not.
3:41:24 PM Jeffrey H Most likely, you are active the entire time you are in the forum.
3:41:58 PM Jeffrey H Anyone else on the forum, may have left for a cup of coffee or something to pull them away from the desk and that would cause an auto logout to occur. This is a common security feature built into most login based systems.
3:43:07 PM Matt Farr Why would this suddenly be occurring now, when it has not been an issue for the last decade? We did not upgrade the software.
3:43:50 PM Matt Farr vBulletin user name: XXXXX password: XXXXX
3:44:43 PM Jeffrey H Sir everything in here is functioning perfectly.
3:44:52 PM Jeffrey H Your users who are reporting this went idle and were auto logged out.
3:45:18 PM Jeffrey H Again, in the article above it is indicated there is a way to update this timing.
3:45:19 PM Jeffrey H Is there any thing else I can assist you with today?
3:46:19 PM Matt Farr Did server software get upgraded or modified in the last week?
3:51:30 PM Jeffrey H No sir, this did not occur. I have confirmed this.
3:51:37 PM Jeffrey H Thank you for using Live Support. If you could take a minute to let us know if your questions were answered and/or your support request was resolved, it would help us to improve our customer service. To do that, just click the button that says "Rate and Exit" in the upper right hand corner. The survey takes less than a minute to fill out.
This chat session has ended.
