A few more day a few more things done. Oil pump, front end plate, crank timing gear, cam w/ timing gear, oil pan, flipped the motor CAREFULLY.
Head gasket, head, torque them down. Used royal purple on the bolts as our “light coat of engine oil on the bolt threads and under the bolt head” because it is what we had left over from an oil change earlier that day. In this I am also skipping the amount of time spent cleaning. I think right now the engine build has been 10% putting parts together 5% looking for where a part is, and 85% cleaning.
Here one of those previously mentioned road blocks popped up. The push rods have disappeared. Spent about 2 hours searching the garage, then some more time checking the truck and any other boxes that might happen to contain auto parts. Decided they were not around and we would have to call the shop and find out if they had them. Quick strategy sesh later we decide to finish putting it together, at least to the paint stage, basically already there. After painting we’ll take off the covers to put the lifters and push rods in.
Spend the rest of the day masking and that’s were we are at for now. Decided to wait for warmer weather to start the painting as it was 10 in our garage this weekend even with the small heater going. Luckily Colorado has decided that it is going up to 50 by Friday. While masking the front, do y’all mask the whole machined surface or just the surfaces that line up with cooling components?
I called the shop before posting this and still have no idea what happened with those push rods. I figured the shop didn’t have them, calling was a hail marry. They were in a box that I brought with me there but I think they just took the pistons and lifters out of it, leaving me the oil pump and push rods. The old oil pump is around, but no sign of the push rods. Now I’m looking around for new ones. Probably the smart thing to do anyways as I have a new cam and lifters. My question is do I need to go OEM or are aftermarket’s ok for these. The dealership quoted me $435 for 12 push rods. Cruiser Corp has a set of 6 aftermarket’s for $99, bringing the total for 12 to $198 + tax & shipping. Not sure if there are other aftermarket’s that work, the website does not list what company makes this set of 6.
