Looking for SAS parts for Lisa’s 3rd gen. Dimond housing, rock assault, or I might swap to passenger drop and look for a 80 front axle, top shift gear driven transfer cases, etc.
Let me know what you have.
Well I guess that's one way to fix her front end clunk lol. NGL when I was bending my cam tab back the other week I was thinking it would be nice to SAS. Wanting to do it even more after seeing 2 SASed 3rd gens on the snow run. I've also seen some people chop an 80 axle and keep the carrier on the driver side Seems like it could be simpler than doing an exhaust reroute. I'm definitely interested to see how much you end up being able to pull off a SAS for.Looking for SAS parts for Lisa’s 3rd gen. Dimond housing, rock assault, or I might swap to passenger drop and look for a 80 front axle, top shift gear driven transfer cases, etc.
it's going to be a min, but collecting has begunI'm SO excited I can't wait to get this done! Thanks Babe! you're the BEST!!
So are you doing leafs or three link?it's going to be a min, but collecting has begun
Leafs for nowSo are you doing leafs or three link?
Budget build. Leaf springs party harder anyway.So are you doing leafs or three link?
no front end clunk in my truck, just want a "better" build I want to be able to follow the big boys on the harder trailsI did a sas to eliminate front end clunk too. Let me know if you have any “how to” questions.
Sooooooooooooooooooo...... No longer a budget build.Budget build. Leaf springs party harder anyway.
so I'm told 😜The sas will be much better than ifs.
This will most likely be changed into the build thread, once it starts.I ran the numbers and thought about every option of axles. The rubicon axle did come to mind but they are hard to find. I went diamond. After buying a junkyard axle and replacing everything so it was fresh and reliable, it would save $300-$500 over the diamond. And the diamond didn’t need to be trussed or old mounts removed. Not trussing the axle, I can tuck the axle tube within an inch of the oil pan (the panhard bar needed to be bent in a S shape to also tuck to the oil pan). My diamond is is 66” wms and things get very tight even at that width. I kept my build as low as I could without raising the engine. I went with 35” tires and I’m not sorry. I did end up doing a full rear suspension rebuild. I had to lift the rear to match the front (completely build the front first). Lifting the rear caused a roll axis angle of 20 degrees of oversteer and 69% anti squat. It took some planning (and luck) on where the shock towers poke into the engine bay.
Time to start a build thread.
Definitely interested in a top shift case.I have a couple gear driven Tcases (84-95 or whatever) cant remember if top or rear shift, you can take a look and see if they fit your application.
