RicardoJM
Few questions for those of you that have experience with rear shocks on the 40s.
First questions regards the lower shock mounting post. The previous owner replaced the rear end but did not install the shocks. I did some research on MUD and it looks like I could use the hole in the center of the plate (between the springs and the axle) for mounting the lower post. Alternatively, I could find a u-bolt plate with shock posts. I'm leaning towards using the hole. Have any of you 40 owners mounted your shocks here? As I do not have a lower post, what would you recommend I do to get a post in place?
Next questions, regards getting the right sized shocks. I placed a high-lift jack in the back corner and lifted to flex the spring and measured the distance from the center of the hole to the center of the upper shock mounting post as 19". Next I placed a floor jack right under the u-bolt plate to compress the spring - this measurement is 15". Without any lifting/compression the distance is about 16 1/4". How does this compare with measurements any of you have for a "stock" FJ-40? Would you have a part number or shock recommendation for rear shocks?
