FJBen
0
- Joined
- Aug 25, 2005
- Messages
- 892
crosspost from mud...
Driving back from band practice last night around 10:00pm. I was on the highway for about 10-15 miles, was slowing/coasting down from 65ish MPH when I head a "pop" and then I'm in neutral. Ok, well I just thought maybe she popped into nuetral. Slow down to stop at the light, when I go to take off again...let the clutch out...VROOOM no moving.
Ok, somewhat strange, try again...no engaging. Mind you I'm on a highway that people go 65-70 on and I'm stuck at the intersection at 10:00 at night. MANY semi's travel this route. So I get out, manually check the t-case, move into low range....get in...same thing VROOM with no go when I let the clutch out. Doesn't matter where I put the high/low selector (and it still feels like it's hitting each detent when I move it on the case)
I don't hear anything grinding or horrible noises but you can hear the gears in the tranny turn if you listen close enough. Thankfully I have good friends that come and rescue me in the middle of the night. THANKS! I got towed to my house and now it sits in the garage...again...
67 Fj40, 350, SM420, 3speed case
thoughts? where to go from here?
