Pie cuts to bend square tubing?
Rezarf
In Uncle Ben's Shadow
Howdy-
I am going to give this a shot. I want to use some square tubing to make my fenders for my trailer. Will cutting a bunch of slits in the steel net a curve? I used this technique with wood before and I am thinking steel wouldn't be that hard?
What about heating the tubing up with a torch, would that be faster? Cleaner?
Thanks!
Drew
treerootCO
Relief cuts would be better than bending. The tube will crush if you try to bend it. Another trick I have heard of is fill the tube with sand before bending it. The sand is supposed to support the tube and keep it from crushing.
Howdy-
Thanks!
Drew
Beater
denver
root's right, section it, but not multiple cuts. and you will need to heat it. if you don't have a rosebud torch, you can use mine if you are victor. or bring it by
j
IanB
0
Just this side of reality.
You can get dies for bending square tubing.
Evergreen
I cut it on a bandsaw and weld it, but that's me. You can always grind the welds smooth and hit them with a flapper disk for a "one piece" look.
