gr8fulabe
Hi everyone,
I finally went to go and try and bring that 74 4j40 home last night. Spent many hours in the cold rain but didn't bring the truck home.
Mostly because they hadn't gotten everything ready to go like they said they were going to so I spent a ton of time digging parts out of nooks & crannys.
but the reason I ended up not moving the 40 was this.
It has an offy intake, with header & holley carb on it (from years ago, supposedly the source of the 20-25 miles per gallon). I got it started pretty easily after it charged for a while, but it would die out again really quickly if I didn't keep the rpms up. Then I noticed that there was gas pouring out of the carb and onto the header. I didn't want to try driving it & end up with a fire, so I left it.
I can always rent a tow dolly and get it home that way, but I wouldn't mind getting it running as quickly/cheaply as possible. I plan on doing a lot with it, but I wouldn't mind getting to drive it some for a little while before it goes completely under the knife...
So what would you guys do?
1. rebuild the holley carb (not a great idea I figure, but a carb rebuild kit would be cheap & it would give me a chance to try that on a carb I don't care too much about if I screw up).
2. buy a new holley carb since that is how it is currently set up
3. but a new or used oem carb. (preferably one that just needs to be bolted on so that I can roll quickly, rather than works, but needs a rebuild).
Thanks for any advice.
Best,
Abe
Best,
Abe
